from this long, tedious thread :|
http://www.s10forum.com/forum/showthread.php?s=&threadid=76533
Latest problems:
Its' frozen outside, and when I went to go start the s-10 and warm it up...it was acting as if it was running on 3 cylinders.
It was - the brand new Autolite plugs were fouled (3 of them) to the point they would never fire. I drove around on 3 cylinders for as short as possible to go have someone look at it.
*didn't happen as each place was swamped with people freaking out about a little snow that will drop soon tonight.
So I went to shucks and bought the next highest heat range plugs, and go home.
Whoa!
I'm getting this smoke inside the truck building more and more and can't figure out where it was coming from - when I arrived home from the shucks (just up the road basically)...I hear this "sizzling".
I'm freakin out man...what the HELL is that?
I look everywhere, then under the truck. My new flowmaster Cat conv and part of the pipe is RED HOT!! Visibly RED HOT (like in a cartoon red hot).
I shut the truck off asap.
I let her cool. Put the new sparks in (6 in the next highest heat range from stock)...fire it up.
Bamm - works great (even a bit smoother than the other new plugs).
I watch that cat conv like a hawk. Drive it around, check it. etc.
I was burning tons of fuel in the cat basically. Sign the plugs were not doing their job.
Cat isn't heating like that now and she's running well....but man, i can't have this happening (brand new cat which is probably toasted a bit now).
I just had a total tune up (see earlier in this post), but i'm finding out this whole fouling thing happens upon cold starting.
What are all the things that might be the cause to make plugs foul at cold start?
I do have a tough time getting gas in the carb at cold start.
I mean, it's ridiculous how many times I have to start it now.
But....the strange thing is, 3 places don't feel the carb is that bad to cause this. They drove it and looked at it.
So now I'm suspecting:
- bad spark cables (i bought the run of the mill shucks cables).
- flooding upon cold start (I'm trying not to...but I have to give some gas because it's taking way too many cranks with no fire up).
When it fouled this last time, I had to floor and hold the gas pedal to get it to fire...then i noticed the horrid state it was running in (3 cyls) and all 6 never kicked in.
The fouled plugs were: 1, 2, and 6 in the firing order btw.
So how does one start the thing when it's so finicky about flooding or fouling?
Boy, I've sank enough into this little bitch. She rides great right now...but who knows when this will happen again.
any help on causes of this would be great. What does it really mean to put in the next highest heat range plugs?
Thanks and sorry I'm back again with this shit,
Joe
BTW: I should change to a new thread, as the new return spring worked wonders on the aching leg (doh, why didn't I think of this 2.00 part?)
Latest problems:
Whoa!
Joe
