i tried for hours to get the shocks on an then i gave up. but then i had an idea would it be easier to mount the top of the shock and then put the coil spring on
an mount the bottom?
what other ways are the best and easier
Low & Yellow
Save the shocks till last, they'll slide ride up through the coil spring. You'll just have to push up on the bottom of the shock to get it to compress to start one of the bottom shock bolts.
Squid Life
slammed03s_dime said:
does it mount inside of the lower control arm? or below on the outside of it?
Did "YOU" take it apart? It mounts to the outside...slide the shock up through the lower control arm and bolt it to the bottom.
thats what i though but i didn't want to hook it up wrong. thanks for the help
if your trying to get the shock in the coil the esay way would be to get a spring compressor, you can rent one or buy one. but that would be the easy way to get the shock in the coil.
