1 - 14 of 14 Posts
THE ONE THE ONLY
MY PULLEYS FROM MARCH PERFORMANCE ARE COMING IN TOMAROW WHO KNOWS THE BELT SIZE I DON'T WANT TO **** AROUND AFTER I GET IT THOSE BASTURDS ARE GOING STRAIGHT FROM THE BOX TO THE TRUCK. IT'S A 2 PEICE STEEL FOR THE CRANK AND ALT. I NEED AN ANSWER NOW SO I CAN GET IT FIRST THING IN THE MORNING!!!!:02redxbla
killin em softly
Im sure if you used the search button that you could find the size belt needed. I cant imagine that this has never been discussed.
THE ONE THE ONLY
hey thank you very much :) thanks!!
I'm sure the kit will come with instrucs and the belt size should
be included. That's the way it was for the ASP's I got.
I'll tell ya though, if I had known about the BBK alum pulley
kit Truck Performance has for my ride now, I would of bought
them. I've seen close up and they're clean. Three alum pulleys
for 130.00 and change. They have em up to 95. Good deal for
1st Gen and some 2nd Gens..Only thing you have to match
would be a belt since the BBK's are 6 groove pulleys and the
factory's are 8 groove pulleys..Not all are like this, but some.
www.truckperformance.com/products/?productID=97688
THE ONE THE ONLY
lol your not the only one i didn't even think to check them i only ever heard of marches pulleys
If you look at the instructions that come with it, 6 rib 91.5 long belt. XX60915!!!
Working Hard at Life
I have the march pulleys as well, but not installed. Is a pulley Puller needed? My friend has a WS6 LS1 v-8 and to change his pulleys he had to rent a pulley puller, but he got the wrong one the first time. Apparently with ours all you need is like a breaker bar b/c i have heard no talk about the need for a puller. Anyone who has added the pulleys already please respond.
thanks in advance
Derek
As far as I know there is no need for a puller. I had three bolts
on the harmonic balancer that had to come off, the four bolts
for the water pump puuley and I had to take the alt off and
take it to a friend's parts store so they could use an inpact
gun to take off the alt pulley nut to replace the stock pulley
with the larger one. I should of kept the stock on. Charging
is reduced at idle but does come back up as soon as 800 R's
are reached..
Quicker than a Hummer!
you replace the stock pulley with a smaller one-
I didnt have an impact... I used a pipe wrench on the old pulley to hold it.
i wrote a bunch about the belt size earlier..took me tooo MANY tries to get the right one!
THE ONE THE ONLY
Discussion Starter #11
the pulleys on ours just pop off with an impact i put them on my freinds about 4 weeks ago and i never needed a pulley puller they come off very easy you kinda need an impact though it's not totaly nessecary but it's just much much easyer that way
THE ONE THE ONLY
Discussion Starter #12
forgot to say UPS wasn't not all over it today and my pulleys did not come today....thanks UPS 3-4 days WHY DON'T YOU JUST SAY FOUR THATS WHAT YOU REALLY MEAN YOU ASSHOLES!!!
yeah dont need a puller.
impact wouldve been nice but pipe wrench worked fine too!
1 - 14 of 14 Posts
