so i started pullin my transfer case around noon today and had it totally out by 130. i was thinking of taking it to this transmission shop to have them install my sye kit and front output shaft but they wanted $480 to do that & rebuild it. i started pulling it apart and was able to replace all but 2 bearings which are somewhere inside the planetary set somewhere, and the front seal which i havent been able to pull apart but i think the bearings that i have are supposed to go in there. the entire install was pretty easy except for that. you need a good set of snap ring pliers but other than that everything goes together like a shish-kabob (sp?) with snap rings. i got everything together except for those 2 bearings which i need to figure out how to pull, and i decided i want to get the 2wd low range kit, so i am going to order that tomorrow. when i ordered all this stuff i also ordered the jeep style front output shaft that takes a u-joint. now i dont know where the hell the yoke is that it came with for the front. i have everything except that yoke and the gasket for the trans to t-case. i also found a tube that had a hole worn in it. i think it is a vent tube but i think it got worn out when the rear motor mount broke because i could see where it hit the bottom of the body heh. so i think i can find a length of tube at my work to replace that. i was also thinking i can ditch the vacuum stuff that goes out of the top of the transfer case. i dont think i need it anymore cuz i dont need it with my sfa. i dont know where the rest of the tubes go cuz 3 come out of the transfer case, i think only one goes to that vacuum thing under the battery and i dont know where the rest go...
