1 - 10 of 10 Posts
Color of puff of smoke? Year and engine? If it's just a puff of white it could be water vapor that accumulated in the exhaust piping. If it's just a puff of black it could be a bit to much fuel on startup. No harm.
How long does it last and is it mostly transparent or is it a cloud?
First in the morning or setting most of the day a puff of smokes comes out has gotten a little worse over last several months
My ‘86 shoots a puff of blue smoke when I start it sometimes too. Mine I think is caused by bad valve seals so when it sits a little oil gets in the cylinder then burns off when I start it. It sounds like a pretty common theme with 80’s GM from what I’ve heard. I just check the oil often and keep it topped off and haven’t had any issues.
I have a touch of emphysema that sorta acts that way even tho stopped smoking 3 decades ago. Almost afraid to pursue the cause which undoubtedly linked to aging components.
If it's Blu and cyl heads never been touched, olden sten seals likely crumbled.
Cats don't like extra oil much at all.
^^^ yup, thinking the same thing^^^, valve seals.
Drain 1 quart of oil and replace it with a quart of ATF or Risoline or something of your choice.
I prefer ATF, but that's just me.
Drive the vehicle for a couple days or a week, then do an oil change with new oil and oil filter.
Substitute 1qt oil with a valve seal conditioner such as Lucas engine oil stop leak, Liquimoly oil stop leak, etc.
And you should probably add a quart of Lucas or LiquiMoly at each future oil change.
Before adding the oil additive, you should start with new oil and a filter.
But it's not a huge problem to have the heads reworked at a machine shop. That'd stop the problem all together.
1 - 10 of 10 Posts
