1 - 12 of 12 Posts
if you need part numbers for the items at hose and fittings, just PM with what your looking for. Size of threads, size of tube ends, type of fitting, elbow, straight, etc.
I would recommend DOT compression fittings over PTC's tho. and I think that they are cheaper.
but when i comes down to it push connect is the shi t i get mine from parker and yes they are dot approved
or just look in the phone book for parker.com most likely their is on around all of you or a grainger.com but from their you have to buy 10 packs
Yea...DOT PTC's would be aight.
Like I said, If you need any part numbers to find your way around hoseandfittings.com, PM me with what you need.
grainger has everything you could possibly need basicly its the home depot of industral stuff, airline, compression, ptc, cylinders (not for car or truck use but can use them for other things like flip up tag bracket)
dubdS10
Grainger, Fastenal..etc They are industrial distributors, you could get nearly your whole airbag system from them if you wanted to.
Nate
1 - 12 of 12 Posts
