1 - 20 of 687 Posts
Damn right I'm a maniac.
I kinda figured that everyone would eventually get tired of me bumping my pic thread every time I changed something, so I decided to make a project thread. I'll be posting my updates here from now on, so scroll to the end of the thread for my latest bouts of insanity ;)
Here's the pic thread in case you were wondering where I'm starting at:
http://www.s10forum.com/forum/f3/updated-pics-of-psyko1-tons-of-pics-no-56k-360727/
And here's what I did today:
I had Peter (Crazygenius13) weld up my taillight fillers and bumper extension holes. There was a small amount of metal warping on the driver's side so he used a stud gun to pull the metal back out. I used the FBI taillight fillers so they don't fit perfectly; I'll need to do a layer of kitty hair to bring out the contour of the fillers to match the curve of the tailgate, but for the $15 or so I paid for them, I think it's worth the extra work. I had to take off early so the tailgate is still at Peter's getting worked on, but I'll hopefully be picking it up tomorrow or Monday. Stay tuned...
Discussion Starter · #2 ·
Todays progress; ground down some high spots, ready for the kitty hair.
Also picked up the tailgate from Peter. He went ahead and did the kitty hair on the gate for me, so it's pretty much ready for filler.
This picture shows how much I'm gonna have to build up the kitty hair to match the contour of the tailgate; about 3/16"
If I get motivated later on, I might do a little more work tonight...
thats a little bit more filler then you should use. it may crack on you. i heard 1/16th was the max but im new to this as well!
What y'all watchin HOES!?
Damn you posted pics quick! hahaha
Kitty hair and filler are 2 different things. You don't want either to be build up very high at all, but using kitty hair as a base for anything like what Jay is doing is much better than just slapping some filler on there.
I use a coat of kitty hair on everything I shave, before doing the filler. I have never had one thing I've shaved crack on me. If you don't use it when you shave stuff, it may look good, and work for a while, but the 'glass base seems to add a bit of extra strength to any patch panel or area that needs large amounts of filler.
is a Prick.
Damn man.... Thats a scary amount of filler to put on!
Did you warp the filler piece in, or did you order a flat one?
Not saying it hasn't been done and worked for now, but, on an exposed, outer curve like that the filler stands a higher chance to fail as well.
Sweet! What about that Metal to Metal Stuff? Use that on the fillers to build it up?
Not familiar with that product, I'll have to research it. Thanks for the tip!
They're the cheap FBI fillers; they don't have the compound curve that matches the tailgate. I still think I can make it work. Worst case senario, if it cracks in a year or two, I can cut 'em out and redo it with Grant fillers at that point, but I don't think I'll have that problem since I'm using fiberglass for the majority of the thickness. I've layed kittyhair thicker tan this before and it never cracked.
Yeah, I would never recommend someone to put that much filler on something. Like he said, the majority of the build up will be with the fiberglass (kitty hair) then minimal amount of regular filler.
There really aren't too many other options other than pie cutting the pieces and work, or get a grant piece.
is a Prick.
Well if you're willing to re-do the work if it fails, go for it.
I've never had experience with the grant fillers,i hear they're clutch tho. My friend got a set of fillers when we were doing his S10 and he was lead to believe they were grant, they turned out to be lower quality than FBI. Flat as a board. We wound up pitching them out and I made some on the English Wheel, like I wanted to do in the first place....
Discussion Starter · #11 ·
Got a little bit done tonight, laid up the kitty hair on the driver's side taillight and DA'd it with 40 grit. Still needs some sanding but my air compressor kept flipping the breaker and I got tired of ****ing with it for tonight. Got it built up enough to match the curve of the tailgate, but I keep ending up with divots in the edge. I should be able to finish sanding this layer down tomorrow and have it good enough for filler. Here's the pics:
Discussion Starter · #13 ·
I might have to give that a shot. I've been beating the hell out of this little $15 Harbor Freight DA (and the garage circuit breaker :haha:) Made some more progress while the forum was down.
Sanded last night's work some more, determined it still had a few low spots that needed to be built up:
Did a lot more sanding and I think the driver's side is ready for filler now:
Getting started on the passenger's side now:
I'll Miss Ya Red!!!
Shit That's coming along man! I need to get off my lazy ass and start making some progress instead of living vicariously through other's projects! LOL !
Discussion Starter · #15 ·
More progress today. Got the passenger's side fiberglass work done:
Another view:
Some filler:
More filler:
Even more filler:
Damn I'm sick of sanding...
Discussion Starter · #17 ·
Damn I cant imagine doing all that in just two days. I'm sure experience helps tho, you're a pro and I'm learning as I go. At least I'm not having to sand everything by hand :eek:
Discussion Starter · #19 ·
Ok so I need to pick up a foam block and a rubber hard block, what should I use each one for? What grits of paper should I use for block sanding? My plan was to DA the filler with 80 grit to get it to the rough shape I need, then DA again with 120 to take down most of the 80 grit sanding scratches. What should I start blocking with? Also would it hurt if I spray the work with some cheap rattlecan primer to use as a guide coat for block sanding? I'm thinking about picking up a quart kit of this stuff to use as a sealer once all the bodywork is done:
http://cgi.ebay.com/ebaymotors/1-Qt...318QQhashZitem190242484652QQitemZ190242484652
Any experience with that brand? Would I be better off getting gray or red oxide sealer since the truck will be painted black (I figure it might be kinda hard to spray black paint over black sealer)?
1 - 20 of 687 Posts
