1 - 20 of 36 Posts
Well, I had my ps2 setup in my truck for about a month and just got all the bugs worked out.....and still the FM mod has to go. I'm seriously looking into this CDA-9813 cause i've heard great stuff about em. I was wondering if anyone has anything bad or good to note in addition to the crutchfield and alpine official specs. I currently have one kicker 1200.1 for my two subs, and a 4 chan fosgate 900 amp for my mids/highs, and i also have a ps2 which i want to hook straight up through the aux inputs (and i think i need this adapter Alpine KCA-121B). Im guessing i should be able to hook all this up to the cd player with no probs, but I just wanted to see what everyone said. And heres the specs if ya didnt know em:
CD Changer Control
CD Text Display/Scroll
Disc Play/Pause
Disc Title Memory
Forward/Backward
M.I.X. One/All (Random Play One or All)
MP3 Changer Ready (CHA-S634)
MP3 Text Information Display (ID3 Tag)
Multi-CD Changer Control (with KCA-410C)
Music Scan/Repeat
Music Sensor Up/Down
CD Player
CD Text, CD Text Display, CD Text Scroll
CD-R/CD-RW Compatibility
Digital Servo
Disc Play/Pause
Disc Title Memory (24 Titles / 8 Letters)
Forward/Backward
M.I.X. One (Folder)/All (Random Play) Music Scan/Repeat
MP3/WMA Decoder/Playback
Music Scan/Repeat
Music Search Function
Music Sensor (Up/Dn)
Quick SearchTM Function (MP3 files)
Regulated 1-Bit DAC
Zero Data Mute (0 bit Mute)
CD Shuttle Control
Disc Play/Pause
Disc Title Memory
Forward/Backward
Music Scan
Repeat
General-Head Units
6-Channel Digital Time Correction
6-Position HP/LP Digital Crossover (24dB/Oct.)
Media Xpander™ (MX)
Parametric Equalizer
Subwoofer Level Control
Subwoofer Phase Control
3 PreOuts (4V PreOut)
3-Color Display with Spectrum Analyzer
3-Way or 2-Way Digital Channel Crossover
4 V PreOut with DC-DC Converter
60W x 4 V-Drive Amplifier
Anti-Theft Detachable Front Panel
Audio Mute
Bass Engine Pro®
Black Face w/Green Illumination Buttons
Black Out Display
Demo Function
Detachable Trim Plate
Dimmer-on Input
Fader & Balance Controls
MM Driver (Hard Disc Drive ) Ready
MobileHub™ Ready
Power Antenna Lead
Remote-on Lead
Rotary Encoder Volume Control
S.T.M.(Source Tone Memory)
Swing Face Mechanism
Versatile Link Ready
Wireless Remote Control Included
Tuner
Auto Memory
Local/DX Selection
MaxTune SQ Tuner
Preset Address Indicator
Preset Stations (FM:12/AM:6)
Station Title Memory (18 Titles / 8 Letters)
Title Search Menu/Scroll
Up/Down Seek
XM Control
Category Search
Preset Memory, 3-Bands (18 Total)
Quick SearchTM Function (Channel Selection)
XM Ready
XM Text Scroll
AM Tuner
Tuning Range : 530-1, 710kHz
Usable Sensitivity (IEC Standard) : 22.5/27.0 (µV/dBf)
CD Player
Channel Separation (1kHz) : 85dB
DAC Type / Number of DACs : Regulated 1-Bit / 6
Dynamic Range (1kHz) : 95dB
Frequency Response : 5-20k Hz (±1 dB)
Oversampling : 8X/352.8kHz
Sampling Rate : 44.1kHz
Signal-to-Noise (S/N) : 105dB
Total Harmonic Distortion (THD) : 0.008% (at 1kHz)
Wow & Flutter (%WRMS) : B.M.L
FM Tuner
50dB Quieting Sensitivity : 13.5 dBf(1.3µV/75 ohms)
Alternate Channel Selectivity : 80.0dB
Capture Ratio : 2.0dB
Mono Usable Sensitivity : 9.3dBf (0.8µV/75 ohms)
Signal-to-Noise (S/N) : 80.0dB
Stereo Separation : 45.0dB
Tuning Range : 87.7-107.9MHz
General-Head Units
Chassis Size (W x H x D)in : 7"x2"x6-1/8"
Chassis Size (W x H x D)mm : 178mm x 50mm x 155mm
Continous Power Output (Note 2) : 27Wx4
Maximum Mounting Angle : 30° from Horizontal
Maximum Power Output (Note 1) : 60Wx4
Nose Piece Size (W x H x D)in : 6-3/4" x 1-13/16" x 11/16"
Nose Piece Size (W x H x D)mm : 170mm x 46mm x 18mm
Operating Temperature (°C/°F) : 60°C (140°F) to -10°C (14°F)
Power Requirement / Fuse Type : 14.4V DC (11 –16 V allowable) / 20A (ATC)
Pre Output Voltage (Before Clipping) : 4 Volts
Weight : 1.5kg (3lbs. 5 oz)
Remote Control
Battery : 2 x "AAA"
Dimensions (W x H x D)in : 1-21/32" x 4-25/32" x 29/32"
Dimensions (W x H x D)mm : 42mm x 121mm x 23mm
Model Number : RUE-4187
Weight : 50g (1.80z)
CURL UP AND DIE
i own that deck...get it. or the 9815 the 5 band parametric kicks all ass and the v-drive amp will run all the high end loud and clean. Ant
good deck we just got my bro the 9811 for christmas and he loves it...cant go wrong with alpine.
CURL UP AND DIE
i didnt run the battery to the deck....the reason they say to do that is because the internal amp puts out the amount of power that it does. i havent had a single problem at all yet. Ant
Its a good deck, my friend has the same one and he is runnin 2 jl wit 2000wts.. trust me u will like it...
1 - 20 of 36 Posts
