1 - 20 of 53 Posts
· Premium Member
I purchased this s10 prior to covid so not much got done at all. Most everything done is cosmetic.
I purchased the s10 from a guy selling it for his daughter, it was advertised as a 2003 ended up being a 2000 my bad for NOT checking.
The night it was towed home, 2.2 blown headgasket, GM 4l60e new from chevy, truck is wet in pic
351053
Removed the center console and separated the seats and added a floor shifter and console.
351054
I found a Cervini hood locally at a good price
351055
Since I have 3 sets of C5 wagon wheels I decided to put them on as well.
351056
I went to my favorite salvage yard to pick up an 8.8 but was lured into the s10 section only to find the 8.5 big 10 bolt complete well come on guys you know I got busy with a quickness!
351057
Got it home for a bath
351058
Then some semi gloss black paint
351059
Then rolled it out to the s10 for the instal
351060
Of course the rotors and pads were shot so I had to put on some slotted and drilled rotors yes I forgot to put a few new studs in.....
351061
It is time for a little body work since the bed has the damage hardest to repair (for me) that is....
351068
Bumper pulled off.
I tried to use a stud welder but the crease was just not working with me so I did 3 spots and let it set for almost a year lol
· Premium Member
Discussion Starter · #2 ·
Today I got some courage to work on 1 of the 2 dents in the bed corner. The crease is almost gone now. Tools were, small dolly, block of wood and a hammer oh and a propane torch.
This is not by any means a show truck build of any kind I just want a clean looking s10 to thrash on the track. If I continue to work with the metal I should be able to minimize the amount of filler.
351069
More to come, I have never been one to take photos of work in progress but I am learning.
· Premium Member
I bought a pair of doors from a clean Jimmy and the guy tossed in both fenders and of course this s10 has one aftermarket fender on the passenger side and a bent fender on the driver's side so that worked out great
351078
351080
· Premium Member
It started off as a turbo Ls project but I have changed my mind a bit 😏
Good luck with it. What color red is that? it looks a little darker then mine which is victory red.
Just a heads up, you may want to check those jack stands for a recall. I know not long ago Harbor Freight was recalling jack stands due to collapsing. Not sure how old those are they look fairly new so probably not in the recall but better to be safe.
· Premium Member
Discussion Starter · #7 · (Edited)
Not sure of the actual color it looks red but its more of a burgundy color.
Those Jack stands were returned to HF without incident once I found out about the recall. Scary thought
Reactions: fattboyzz65
· Premium Member
Time to clean up the flower pot s10
· Premium Member
Discussion Starter · #9 ·
Just got back from the bone yard with my new 8.8 Explorer rear end. This 8.8 was purchased for my 2002 s10 until I saw it had 4.10 gears in it so it is now going into the flower pot and the 8.5 will go into 2002 since it has 3.42s WIN WIN situation.
Freshly pulled 8.8
351224
Degreeser and pressure wash, works like a champ.
351225
· Premium Member
Discussion Starter · #10 ·
17x8 C5 front wheels getting ready to get widened to 17x11
351502
· Premium Member
Discussion Starter · #11 · (Edited)
Today started off as another trip to the boneyard in search of spare parts for both trucks. After a little hunting I came across a clean little Oldsmobile Bravada that still had the bumper cover and driving lights intact. I think it will look sweet on this truck once it gets a small modification to allow the s10 grille to fit🤫
Now I have to get new lights, the old ones are not worth polishing out.
351844
351846
Well, I 110% forgot my issue with this truck. Prior to me the front had taken a hit and the replacement core support is an aftermarket POS and the holes for the pinch tabs are way off I need to pick up another core support from my local boneyard.
· Premium Member
Discussion Starter · #12 ·
8.8 4.10 gears all painted and ready to be installed. I do have new stainless brake lines on the way
351881
Reactions: graphic dave
· Premium Member
Discussion Starter · #14 ·
· Premium Member
Discussion Starter · #16 ·
BTW, I don't know if you noticed, the 8.8 passenger side axle and tube is 3 1/16" longer than the driver side...
Yes, I sure do. My first 8.8 instal was around 1999/2000 I use corvette wheels 95% of the time either I redrill the pattern or I put 1.25" spacers on it that use ford to chevy pattern.
All is well🤙🤙🤙🤙🤙
Reactions: Mad Max
· Premium Member
Discussion Starter · #18 ·
No not at all, just have a lot of years under my 52 year old belt.
· Premium Member
Discussion Starter · #20 ·
8.8 is in and now I have to order a few parts from Thorbros.com since the 8.8 is much different from the 8.5.
352136
1 - 20 of 53 Posts
