1201 - 1220 of 1547 Posts
Lifted 2wd & Bodied 4x4
Discussion Starter · #1,202 ·
weaksauce.. if decent is an understatement.. then you REALLY should part out the 95. i think u might have meant overstatement though.. i thought u were smart?
decent is an understatement in terms of how shitty it is.
And maybe you should check out the thread for the '95...there'll be some updates that may be to your liking
Say lowered d
Whatever happened to ibanez?
Discussion Starter · #1,211 ·
I plan to put a twin turbo 454 LSX in it that will hopefully max out the block's horsepower rating of 2,500
oh and a T-56 trans (prolly the new redesigned one out of the '08 600hp Vipers) with some sort of beefy rear end or IRS.
Discussion Starter · #1,219 ·
well got the front suspension put back together on the '91. Got the rear done for the most part, just need to dig through all the shit at the shop to find the last wheel spacer then I can put the last wheel on. After that I have a few fitting swaps to do and then I can put air to her and move her around :D
under construction
WOOT!!!!!! this was the first project thread i looked at when i joined up here.........cant wait to see this some bitch....shit, believe 100k is possible if you add up the time/labor/parts and everything.......money goes quick.
