181 - 187 of 187 Posts
I has s475
This is mine I just finished up yesterday. It's a little different from the ones in this thread I used the stock jump seat mount made a metal frame out of small metal rod then glassed all over it. The front of the box is actually a jump seat cover out of a early year s10 with the plastic jump seat covers. To keep it OEM/era correct I removed the stock carpet from my 2003 jump seat and cut the back out and glued it to the front of the plastic box.
In this last pic the panel isn't in all the way so the box should fit a lot better than it does. I hope it sounds good.
I has s475
Do you have an idea of the air space you managed to get with that box? What amp are you going to use? Looks like a really good fit, nice job.
Air space i'm not sure but I could figure it out for you. The size amp I am using is just a small kicker 400 watt I am gonna hide in my jack compartment. Thank you sir it was a lot of fitting and measuring to make it right.
