1 - 20 of 150 Posts
2 LAYLO
Same color primer my truck will be. Dupont select prime 2k ? maybe
Hola Bitches
the primer is good enough ...?? what is it a acrylic enamel ...wont absorb water and such
tune in turn on drop out
Discussion Starter · #15 ·
close im using u-tech 2k, its mostly basf product an green epoxy sealer witch will keep all the moisture out. so it will be a green for a while. an once i pick out my color will be using gluraist clear. im not doing the paint so i gatta start comming up with some ideas an colors. the guy doing the paint also wants to do air brushing .its a good deal all the work for my bike.
what to put here....
looks good
1 - 20 of 150 Posts
