1201 - 1220 of 1222 Posts
Inferno Fab
Discussion Starter · #1,211 ·
I started back on the rear of this. I got one of the MOCK UP cv axles made up. Then I started on the shocks.
Next I will do the other side then install the accuair sensors.
Inferno Fab
Discussion Starter · #1,213 ·
Yeah, both the front and rear get the exact same amount of camber. Its not a lot bc I wanted to be able to drive this real low without chewing up tires. Its about 5* of camber all around.
You can see it here in this pic
Twinkletits
Any particular reason for the frame being so narrow the whole length? aesthetics?
looks great regardless
Inferno Fab
Discussion Starter · #1,217 ·
It was easier to build that way. If you kick the frame out where the front clip meets the cab frame rails then you run into a very difficult compound angle to cut and get right. The plan is once the cab floor is cut out and sat over the frame, I will build a kick out off the frame on both sides to widen it.
Inferno Fab
Discussion Starter · #1,219 ·
Did the forum lose posts? I could have sworn there were posts later than 2014 in here. lol
