241 - 260 of 261 Posts
· time to get cereal
Discussion Starter · #244 ·
Where did you purchase it, and is it built for what?
Mishimoto's website, it's for a Cobalt SS. 2.2l radiators have the hoses on opposite sides of most radiators, luckily this one works. Works with single or dual fans. Probably going to run the single for simplicity. I don't forsee any cooling issues with this setup.
Discussion Starter · #245 · (Edited)
So when I got the '95, the engine had a ticking noise and was told it might be a wrist pin. Didn't really care or look into it since I planned on junking the motor anyway. I did try to sell it but I'm kind of glad no one bit because this is what I found....
Wood Gas Road surface Bumper Font
That and the top compression ring was shattered in pieces on all four pistons, the cylinder walls had deep pits and looked like they were honed with a sheet of dry 80 grit. The rod bearing all had scratches that I could feel with my nails. I'm surprised it ran at all really. @BigPapa
I did manage to gut the entire cab, it is so weird to me to see a vehicle this old with absolutely no rust.
Car Vehicle Hood Blue Motor vehicle
Hood Green Blue Motor vehicle Trunk
Still needs a good cleaning and I need to get some dry ice to remove the sound deadening on the floor.
Gutted the dashboard a little bit and removed the electrics from the steering column and just threw back in...
Car Vehicle Hood Window Motor vehicle
‘95 LS 2.2L Manual RWD
Just logged on for the first time in a long time and saw that piston…:oops:
That‘s just crazy. You drove it some before you stripped it, didn’t you? Did you suspect anything like that? I certainly didn’t. Good thing you weren’t planning to use that motor. I certainly had no idea. We got whodo’d on that truck. Sorry MBP. I hope you don’t think I was trying to whodoo you….:cautious:
Discussion Starter · #248 ·
Haven't done much, still trying to acquire the final parts to build the motor. Working on buying all new connectors for my harness, figuring out what sensors I want to use, etc.
Decided it needed different headlamps. Cardboard mockup...
Vehicle Tire Grille Hood Automotive tire
For these puppies:
Automotive tire Automotive lighting Tire Rim Automotive wheel system
Left is low beam, right is high beam. It'll look something like this:
Tire Vehicle Car Hood Automotive lighting
Also got a flat response knock sensor adapter kit for the 'ol 2.2l.
Automotive tire Asphalt Road surface Gas Auto part
Outerwear Sleeve Wood Grey Collar
Discussion Starter · #254 ·
Looking good. Man, you’re garage is WAY too straight and clean….;):cool:
Ha, I'm just good at hiding all of the junk. I spent most of the summer organizing stuff because every time I'd go to work on the truck, I'd have more time in finding tools and such than actual work getting done.
Discussion Starter · #256 ·
Got 'em, now just trying to figure out how I'm going to make them work...
Automotive parking light Automotive lighting Automotive tire Automotive tail & brake light Vehicle
Automotive parking light Automotive lighting Automotive exterior Auto part Glass
I've heard people talk about doing quad round headlights with this grill, never seen anyone do it yet.
· Old Fart
That lens over the projectors will mess up the light pattern I would think. If you want them behind a lens it should be plain.
Automotive lighting Automotive design Font Headlamp Motor vehicle
Automotive parking light Automotive lighting Motor vehicle Bumper Rectangle
Discussion Starter · #258 ·
That picture was just for size reference. These don't need lenses. Most likely going to cut 2 holes in the lense. Though I was tempted to make a hideaway cover a la Chrysler LeBaron lol.
