Current project at Jackson County Customs of Murphysboro, IL
Vehicle Owner: Corey Wermer (LowNoma22 )of Highland, IL at age 15
Fabricator: Christian Rath (cdog24) - who is not 15
Truck: 98 GMC Sonoma ZQ8, bone stock, regular cab, V6, auto, limited slip, 15,000 miles, perfect condition
Corey’s To Date Provided Parts List
SD super pivot 5-link kit.& frame notch
Oasis XD 2000 compressor
Two Optima Yellow Tops
50ft ½ line
50ft ¼ line
Bell Tech 2in drop spindles
AVS 9 switch box and module
SD single port, bolt in bag cups
Slam Specialties RE-6 200 psi bags (front)
Slam Specialties RE-7 200 psi bags (rear)
Eight SMC ½ port valves
3/8 port SMC water trap
SD front shock relocator kit
Two Air Lift dual needle gauges
One Air Lift single needle gauge
Square D adjustable pressure switch
Shorten driveshaft 1” (last week)
Estimated hard parts needed - some still need to be purchased soon or are shipped
Vintage Air
20 x 8.5 Eagle Alloy 025's with 245/35 rubber
ART control arms
Devious Customs Modified tranny cross member
Battery isolator
Lots o' PTC Fittings
Radiator Catch Can
Front inner fenders
Brake fittings
Adjustable proportioning valve (Wilwood)
Loctite
Starter Solenoid for compressor
50ft ½ air line
50ft 1/8 air line
rear roll pan
front shocks
cut off, grinding, sanding wheels
15ft. 9-wire
wiring (comp., computer, etc)
various crap - zip ties, switches, primer, paint, heater hose, tape, connectors, etc.
If anything here doesn't seem right or you think I have forgotten anything (which I have), please post. Items such as guage, computer, battery, and fuse mounts will be fabricated
50ft ½ line
50ft ¼ line
Vintage Air
ART control arms
Battery isolator
Radiator Catch Can
Front inner fenders
Brake fittings
Loctite
50ft ½ air line
50ft 1/8 air line
rear roll pan
front shocks
15ft. 9-wire
