Never Finished
My truck started acting funny when I got off work tonight. It wasn't idling right, the oil pressure seemed a tad higher than normal, but not too high. The rough idle sorta went away after a while, but it would kinda miss/hesitate/stall at random times. I couldn't tell if the RPM's changed cause it would do it once real quick every now and then...no code has been set though. I can't tell if it's the engine, or if it's something in the drivetrain because it kinda feels like I were pushing and releasing the clutch very quickly.
If I'm not mistaken, the SES light should come on with all the other lights when you turn the key on and the engine is not running right? Where on the dash is the SES ligh located, because mine does not light up with the key on, which makes me wonder if the bulb is not working. If so, there's probably a DTC that I don't know about. I'm going to the dealer tomorrow, but I'd like to see if anyone can help me or has experienced the same thing.
Also, it's kinda making a whining/whistling, and just seems noisier than normal from the front of the engine.
Never Finished
I bought it new with 30 miles on it, but I can't remember ever seeing the bulb light up with the key on.
Never Finished
I took my truck to the dealership today, and they told me there was a service bulletin on it. They had to put a shim on the crank sensor. Weird how it was something that simple
Never Finished
I took my truck to the dealership today, and they told me there was a service bulletin on it. They had to put a shim on the crank sensor. Weird how it was something that simple.
