1 - 1 of 1 Posts
a little background the truck sat for 5 years in a garage before i bought it, i flushed all the fluids replaced the water pump and radiator, replaced spark plugs, wires, dist cap and rebuilt the tbi, replaced the battery and fuel pump ,fuel pump screen, fuel filter i started the truck for the first time it ran rough for a few threw a code and it was code 33, checked map sensor vacuum line and it had a crack at the manifold, fixed this and it now idles high at startup for about 30 seconds then runs a little rough not like it was before but does not die, now if i put it into drive or reverse it will die unless i push in the gas 3/4 of the way or more and when i give it full throttle it will go just a few inches then die it literally has no power im assuming its a fuel pressure issue but im wondering what everyones thoughts are about it?.:eek: thank you in advanced for the feedback
1 - 1 of 1 Posts
