Alsek Spring & Fab Ltd.
use an epoxy primer. it is the only kind that is made to stand up to the environment.
PPG Sprayin Minitrucker
A common made mistake. Epoxy primer will not stand up to the environment. It is not UV protected and it does not resist water. The sun will break it down and it will be just like havin a big sponge on your truck.
If you are just goin to prime a small area, at least spray some shiney rattle can over it to give it some UV and some water protection.
NO PRIMER IS MENT TO STAND UP TO UV RAYS!!!
Hope that helps..
