8 Days ago, I agreed to work on my uncle Chevy S10. He's had it for 10 years. It's his baby. Well it's been neglected as far as Maintenance goes. Originally it was just head gaskets. This turned into a nightmare. But 8 days later about to go on the first test drive. 272,XXX Orginal miles.
I've only ever swapped out my buddies engine in his 98 blazer 4 years ago. That's was simple, easy, and even in the dirt with no electric tools, took me 4 days to swap it. So not much experience with the 4.3. Just plug and play experience lol. Well as of right now, needless to say I know this engine better then the *** I learned on "Hondas"
So I told him 700$ bucks in labor I will do the headgaskets. Pay me half now, and half when I'm done. So i start doing the thang on a hope and a prayer, im not the type to watch a video to see how to do it. I know what to do cause it’s all the same. Every engine. Air, fuel, spark and the right timing/ratio. .....im looking up is torque sequence and torque spec fir the head bolts...then if i run into something that stumps me, yes im pulling my phone out then researching it....well as I'm working... I do notice the cooling system was really rusted out. Like it was the worse I ever seen. I documented this whole shabang. I should have diagnosed it further when I noticed the rusty cooling system but I was trying to rush, cause I'm on probation. Not supposed to leave my county. ..trying to get my license back, ride a bicycle right now, ...just got out of jail, my lifes crazy but im trying. ... Anyway. Me trying to rush the job, I messed some ** up. I crushed the oil pressure switch by accident, it was just so fragile, I was fighting with the 3 exhaust flange bolts on each side, from never being touched in 27 years. Rusted, seized...(least I thought they were) so I cut the exhaust on the driver side underneath right before it crosses into the passenger side. I was just struggling trying to have access to the headbolts that were located on the outside of the head. I did manage to get the heads off with both exhaust manifolds still in the way. Just very time consuming, an aggravating. Eventually pulled the heads off tho, an my God when I did. My jaw dropped. The passages were the coolant flows thru was so gunked up, the ports looked blocked as if the coolant wasn't able to flow like it should. Made sense to me, like ok looks like original headgaskets, an the blockage caused headgasket failure...I thought that's what happened...Not only were both heads cracked, but after I finally put all the back together. .......Literally I can't help it but when I'm doing stuff like this I have bad ocd....everything was so disgusting, the worse case of corroded, gunk, I've ever seen. We should of just swapped his engine out. But he already paid 900$ for rebuilt heads from Napa. So the deal was done. I cleaned everything. The intake manifold, the fuel injectors, the brackets for the pulleys, the valve covers, the throttle body, etc...my goal was to get her to breathe again, to get the fuel flowing to the best I could, to have strong spark to the best I could. I was in the sun, in the dirt. Working with what I had, kinda regretting the situation like damn. I did so much extra . Like cleaning everything. I mean I could of easily put the nasty, gunked up rocker arms, the clogged push rods, the throttle body that had so much crud in it. Idek how it was functioning along with a lot of other . Like the crankshaft sensor. I will post pictures and videos if I'm allowed idk this is my first forum iv ever signed up on. An it's only because of this truck an some information I was needing. But, the dirtiest iv ever had to do. To me as a man, and my name on the truck. No way I'm putting grimy, nasty parts into those fresh heads. Can't do it. Wouldn't be able to sleep at night. Now yeah I cut the exhaust, oil the sending unit up and also up both dip sticks. Bent them, an now its a * to check the fluids. Again that was due to me using a prybar as leverage while having access to the outside head bolts. I'm gonna try an fix them tomorrow but we will see. I did all this work, put everything together, an the last step...that I like to do is add ccoolant.Well I added water first obviously cause I'm testing **. Not trying to waste money on coolant for it to leak out been there done that. Learned so much thus far working on vehicles. Anyway so I add the water and I heard water pissing out. I couldn't believe wtf I was seeing tho, cause I'm unfamiliar with v6 and v8 engines. I love Fwd, familiar with fwd vehicles. Used to be scared to work on anything else but fwd. Nowadays I ain't scared to work on anything. Cause it's all the same.. So I'm looking an really was like wtf is going on here? I didn't know ...but at the same time... I did know....... that this job was far from over. I found out why...the drivers side freeze plug underneath the motor mount was leaking. Iv never changed one but always heard it was hard af...this specific scenario was the worse of the worse. I wanted to give up so many times, but I didn't. I pushed thru thick and thin. I learned so much an now I can say I really do love these engines. The design, "except the location of freeze plugs lol, the durability, and the simplicity of the valvetrain, first time doing headgaskets, valve adjustment and freeze plug on this truck. More so v6 or v8 engines. I have fallen in love with this truck. Not gonna lie has. Has me starstruck, only because of how much work I did, an just the satisfaction of hearing the engine run so smoothly compared to before. I brought her back to life. I'm proud of myself, grateful for the learning experience and have a new profound love for the 4.3L.
To me, My 2 favorite Brands are Hondas and chevys. They are top Dawgs lol. Much love to everyone in the s10 gang.
I got off track lmao but what would yal charge him for the extra work I did, as far as cleaning everything and the freeze plug job. Be mindful of the exhaust I cut, the sensor I broke, a the dip sticks I**** up. Turns out my uncle had a 1/2 drive Dewalt I could of used to get the exhaust flange bolts out but didn't realize that until it was too late. Doing the freeze plug job I took the same exhaust I was having trouble with off with that Dewalt. An it was so easy it made me sick to my stomach. He likes the way it sounds tho lmao he tried saying he wants glass packs on her 🤣
Any advice on what I should charge him lmk cause I'm lost. I'm not good with pricing, I always lowball myself, I have a good heart an it me over in situations ike this. Please someone, anyone, if you took the time to read all this I appreciate you an would love some input. 1st resr drive in the morning, after I put the control arm and **** back together, but during that first test drive, I already know he's gonna be smiling ear to ear. An after that drive he's gonna hit me with how much. 🤔 God Bless and thank you.
