how can i hook my 2 tanks and 2 compressors up so the one pressure switch will turn em both off
X xXx4.3xXx · Registered Joined Aug 12, 2003 · 317 Posts Discussion Starter • #1 • Dec 27, 2003 how can i hook my 2 tanks and 2 compressors up so the one pressure switch will turn em both off
B Braind3ad · Oh, yea... Joined Oct 27, 2003 · 966 Posts #2 • Dec 27, 2003 (Edited) Run a "T" connecting both tanks and put the Pswitch to it.
SlammedDime · Registered Joined Jun 28, 2002 · 13,733 Posts #3 • Dec 27, 2003 He wants to know how to wire them, not how to connect the the compressors to the tanks. check out this thread. Use the one up top, or scroll down a bit to mine. http://www.s10forum.com/forum/showthread.php?s=&threadid=21854
cab · I <3 SPARKS Joined Nov 10, 2002 · 7,977 Posts #4 • Dec 27, 2003 There ya go.. be sure the use them relays.. 2 of em! Or else your pressure switch is gonna go poof!
X xXx4.3xXx · Registered Joined Aug 12, 2003 · 317 Posts Discussion Starter • #5 • Dec 28, 2003 what kinda relays should i use or can i use fuses
L LilRed95 · Drop N Destroy Joined Sep 14, 2003 · 4,712 Posts #6 • Dec 29, 2003 use a ford starter relay
T tuckinrim · Registered Joined Jul 31, 2002 · 1,131 Posts #7 • Dec 29, 2003 ford starter rely is a soleniod dont use one a rely is 4 bucks the the headlight section of autozone ford soleniods are not rated a continuous use and they will burn up quick
SlammedDime · Registered Joined Jun 28, 2002 · 13,733 Posts #8 • Dec 29, 2003 :stupid: Radio Shack has 'em too. 30/40 Amp relay's are what you need, IN ADDITION TO the fuses.
