does any one know what a 4.3L s-10 with a powerdyne should be running in the track. just bought my 2002 s-10 with the powerdyne on it and was just wondering the numbers it is on.
Pill it till ya kill it
Depends on supporting mods. It should go at least somewhere in the 14s though
Super Moderator
If it were mine, I would go through it thoroughly before I would drive it too hard:
Fresh plugs, gapped right
New cap/rotor
check the wires for resistance and replace as necessary.
engine oil
Get the trans serviced
Rear Diff fluid (swap in synthetic)
Clean or replace air filter
Make sure serpentine belt is properly tightened
Check vacuum lines for cracking
Check brake pads/rotors
Check fuel pressure at idle and at W.O.T.
Then I'd install a boost gauge
