After searching many diagrams and pinouts I am left stranded as to what color does what. I am converting my truck to power windows and bought whole doors off a 98 blazer which has enough wires for the rear windows as well but since this is going on to a s10 I only need the front two windows. This is the main harnes and was wondering is there any easy to read diagrams of what colors run to the back windows and which go to the door speakers because i would like to get rid of them.
i saw what you did there!
also gonna be mirror wires and lock wires and so forth
grounds
theres not gonna be an easy way
need good diagram and they are all drawn the same way
this is why i dont even attempt such a thing, and never will
good luck
Electrical Mod
It's really easy. Just look at the wiring diagram, and start marking the wires with tape and labels. Make sure every wire is labeled, then eliminate the wires you don't need. Then start hooking up wires to where the need to be.
hey man yaeh i was actually checking out some of your diagrams...but i figured it would be easier and cheapier to just buy the uni switch that the guy bought in the how to thanks again
