I am doing an LS conversion on my 2000 Sonoma. Could find a P/S pump and bracket that did not hit the power steering gear.
Here are links to the manual gear and the pitman arm.
You have to change the pitman because the P/S output shaft is bigger in diameter than the manual output shaft.
Just got through withe the conversion and wanted to pass this info along.
342546
time to get cereal
If you use the later manual box, you don't need to change the pitman arm...
Moved to LSx Discussion.
