to those that have done the swap, what did you do about the power steering pump, will a 2.8 pump bolt up and work, swap the 350 pump in as well, if you did this was there anything you had to do to the lines or etc?.. we've had to weld the 350 pump tube to the 2.8 tube in the past, theres' gotta be a better way.. ONE more thing, posting pics here, do I have to already need them uploaded them somewhere on the web?..
Secondly, I've got a vette radiator to run, and dual 10" fans to run in front of the radiator, gonna try running w/o flex fan. Running a turbo 350 tranny, this is a swb s-10, the tranny is the 6" tailshaft tranny, can the motor be set up so that I dont have to have driveshaft lengthened or will I need either the 9" tailshaft tranny/or driveshaft from a lwb and have shaft shortened to do that?
Got the motor togather, all parts are in except for my fans which come in wednesday, will be starting the conversion next weekend, and trying to get a general idea from here where I have to go
