1 - 1 of 1 Posts
MY PS lines to and from the "cooler" are leaking under neather the headlight and I have purchased an aftermarket cooler to install. Do I have to run the lines all the way back to where they originate or can I simply connect the new lines where the rubber meets? If I understand and saw correctly the current lines run out under the headlight, across the frong of the truck behind the grill, make a loop and then back under the same headlight.
1 - 1 of 1 Posts
