Is it ok for me to power shift my 01 Xtreme? What sort of wear and tear will it cause?
Say lowered d
Its just going to wear
out your clutch sooner than normal. because when you keep your foot on the gas and let out the clutch to shift it picks up R's quickly and as soon as you let off the clutch, its spinning preaty fast, even though its only 1-2 seconds. As long as you dont miss the gear,:bah: it will be fine on the tranny.
I have an automatic
Sorry about any confusion I may have caused. I have a 4 spd automatic. When I say power shifting, I mean shifting manually from 1 to 2 to 3 then to drive on the console shifter. By doing that, it's a genuine 1st, 2nd and 3rd gear, and I can bring the RPMs higher before shifting. Is that bad for my tranny or any other part of my truck?
Say lowered d
you will be fine
I do that in my impala all the time. It has a turbo 350 with B&M rebuild and shift kit, wwith a B&M fquicksilver ratcheting shifter. Its made to do that. Maybe you could get the B&M electric shift improver to help with the automatic clutch slippage, so it will grab easier when you do shift it manually. But it wont hurt your tranny. Its like holding the throttle down to the floor until the kickdown makes it shift.
The Primered Panther
does it make your runs any faster by shifting manually on the auto's? I tried it once and it didn't seem to make me any faster but maybe i wasn't waiting long enough to shift. Thanx
No. You can't outshift the computer.
Manually shifting a stock auto can be a dangerous thing for the life of your transmission under certain circumstances. If you let the motor rev too high, bad things can happen to your valve train. The stock autos were not designed to run at high rpms for extended periods of time. Quite frankly, they overheat. Additionally, "downshifting" your auto to get that "woooooompppaaaaapapapaaa" sound can also hurt it.
