Hey guys i have an 02 Blazer and for some strange reason the PDL,mirrors and the rear hatch do not work all of a sudden. The fuses were the first thing to check and i came up with NADA! At first i thought the switch was dead for the locks since my camaro has done that but NEGATIVE ready for the kicker the keyless entry works perfectly............
I read in the manual it may be a bad ground but it was so vague in description it just said under the dash:rolleyes: I have YET to get into the whole "search for the problem deal" and figured maybe someone has had this problem....thanks guys:cool:
Discussion Starter · #2 ·
damn no one:rant:
lol its like that sometimes
i saw what you did there!
check circuit breakers in fuse panel
and lock relay
and power lock switch assembly
theres alot of possibilities here
check for power and ground is first step,
I finally got it!!!!!!
I was absolutely flustered that my door locks and power mirrors stopped working all I did
was replace the rear hatch glass actuator, it only popped 1 time very weak at that so I just assumed the USED part I installed was on its last leg. Then about a week later I noticed my door locks and mirrors no longer worked. I always use the key fob to lock and unlock
that always worked great.......
WELL GUYS, the culprit was the fuse under the hood it was a light blue fuse that had an "E" on it I feel stupid in a way cause I knew the locks worked through the fob lol and yes
the "USED" actuator does work properly.........definately overlooked the obvious!
light blue with an E on it, can ya get a pic? i've got the same damn problem, i've tested all my fueses under the hood/ in the door jam and i'm missin something...... power mirrors not working, and locks only work with the key fob......... thanks for the help
scratch that bro, found it, it's a 3 amp fuse ( the only one) mine was purple, and i swear i checked that thing, anyway very helpful, thank you!!
