1 - 20 of 63 Posts
Re: 125db
I am doing a 153.9dB on the termlab right now in my Tahoe 4 15" Immortals, and 8 A18001DT amps
The other "BODY" man
Re: 125db
audio control
Future Shop house of boom competition
1 15 stroker
1 US 2000 at 4 olm
153.3 db
New setup, PG XS 2500, two 10 L7, just for audiofile though!
I like MINE with NO shine
Re: 125db
In my big trunk 01 impala, 2 15's and 600 watts I hit a 148.3 with a 9^3 enclosure, 100 sq in of port, drivers window down on the term lab METER, not the mic. This was an all wood box that wasn't sealed up yet. I ended up cutting it in half, glassing the inside, and I have some PVC tubing cut up ready to go on the edges of the port to get the air moving a bit more smoothly as well as a few cans of undercoating to line the interior of the box. Also, a new 1100 watt at 2 ohm amp ( 1600 at 1 ohm ), dual voice coils on teh 15, and only going with one sub this time. I am going for 151
Chrome sucks-Get over it!
Re: 125db
Requirements for respect:
Legal: Dash, Kick Panel, Drivers Headrest
Mine: 143.6, 146.0, 137.9
What meter used:
Mine: TL usb
If you got metered on an AC, its pretty much a worthless number, as they read about 15 dB HIGHER than they should (when compared to the TL--which is the standard). LinearX can be calibrated to be extremely close to the TL, but it wont quite read the same.
Eric
Re: 125db
Ok, I'll repost with all the proper info. I did a 138.8.:D I did it with 2 12"s (down fire) and 560w (rms) playing music (not tones). All of my amps & subs are Power Acoustik W/a sony deck (that sucks), and Stinger wiring. TL mic on the dash (center), windows, doors, and everything else closed.:tup: I think the other thing that should be mentioned is, if you used tones or music to get these numbers, 'cause that also makes a difference as well. :cool:
Rollin 1st gen style
Re: 125db
nismo said:
yeah, no doubt...I've seen guys doing 160+ port war style with a single 10 or something like that...when legal that same setup will do 127.
What meter used:
Mine: TL usb
Eric
Alrighty :)
Dash: 145 (guessing, it did a 143.x in the old box)
Kick panel: 148.7
Headrest: 145.1 (w00t ;))
AND
Driveby: 122.0 (if you don't know what driveby is, it's a MECA thing were the meter is put 6 feet away from the passenger door, 4.5 feet off the ground, and you creep by the sensor playing music)
All on the termlab, with a single 10" RE seXXX powered by 2 strapped eD nine.1's running at 1 ohm strapped (.5 ohm a piece). Setup sound sick on music, especially for one 10". :p
this is the thread to post your dB scores. in order to keep your post from being hell holed, you must include the box size, tuning of the box, sub model, sub size, number of subs, amplifier model, rms of that amplifier, number of amplifiers, what mic it was scored on, and where the mic was placed. in addition, if you know at what voltage those scores were at, that would be nice as well. if your post does not meet those requirements, it will be gone.
they can be s10's or any vehicle. this is just a reference of the loudest on the site.
S V T is a little bitch
I am not sure if this is S10 only vehicles, I will get my Blazer metered real soon.
These were in my 1985 Camaro with vehicle sealed:
4 Alpine Type R 12" Dual 4 ohm in 3 ft^3 sealed box
2 Rockford Fosgate 500a2 amps running at 500w rmsX1 at 2 ohms each
term lab meter on passenger side dash
143.6db
1 12" Image Dynamics IDMAX dual 4 ohm in 2 ft^3 ported tuned to 30hz
JBL BP1200.1 running at 600X1 rms
term lab meter on passenger dash
136.8db
Truck is toast :-/
I have no clue what meter it was, but I will edit this post if someone can tell me what meter was used at s-series nats this year. anyhow:
147.3 db
2 Alpine type R 12's (swr1222d), 2 ohm dvc
1 Lanzar 1200d (the old school good ones), running as installed 800w rms @ 2 ohm. Can run 1200 rms @ 1 ohm.
3.8 cubic foot box tuned to 32 hz, 40 sq/inch port area.
mic was placed on the passenger kickpanel.
Single Cab S-10, with ONE Memphis Mojo 12" in a ported 1.6 cubic Ft. box, tuned at 45Hz, and a Memphis MCD 1000W amp... 300 RMS @ 4 Omhs. Hit 142.6dB running on the kickpanel, on a Termlab Meter, at Scrapin the Coast. Built a box roughly 3x the size and I'm going to meter again. Will be posting soon!!!
Punk0Rama said:
this is the thread to post your dB scores. in order to keep your score from being hell holed, you must include the box size, tuning of the box, sub model, sub size, number of subs, amplifier model, rms of that amplifier, number of amplifiers, what mic it was scored on, and where the mic was placed. in addition, if you know at what voltage those scores were at, that would be nice as well. if your post does not meet those requirements, it will be gone.
Well, since i can't edit my post.....
I thought i'd make another post to show the details
Vehicle1990 s-10 regular cab
Sub: ONE 10" RE seXXX
Amp(s): Two eD nine.1's running at 1 ohm strapped (.5 ohm a piece). After impedence rise, hopefully getting 2200-2500 RMS
Box: MDF (that's all the details I'm willing to give out right now ;))
Tuning: Don't know, but it PEAKS at 44-46 hz depending on other factors
Meter: Termlab, audiocontrol
Meter placement: passenger kick, headrest, dash, and outside
voltage: varies anywhere from 13.8-15.0 volts
Scores
Termlab:
Dash: 145ish (never officially metered, just a guess)
Kick: 148.7 and getting louder ;)
Headrest: 145.1
Driveby: 122.0 (meter is placed 6 feet away from the passenger door, 4.5 feet off the ground, only allowed to play music)
All of these scores are in MECA class S1, the lowest class possible :)
Audiocontrol:
Dash: 149.x
Kick: 151.9
These scores are before i finished the box and doubled the power ;). I wouldn't be surprised by a 153-154 on an audiocontrol now
Audiomentry
144.7 db at 53-54hz on a TL. Metered again yesterday with an addition of two 8v batts wired in series for 16volts and gained 4.1db but it not offical yet... 148.8 on a TL. All score were measure in the kick.
91 chevy cavaliar
Stock electrical 90amps
Pioneer ph6300
Clarion 5.1 EQ
Soundstream 1400.1 at 14volts
ONE DD 3515 5^ft tuned to 48hz
pictures taken before the batt upgrade.
http://i12.photobucket.com/albums/a221/Camacho111/Picture095.jpg
http://i12.photobucket.com/albums/a221/Camacho111/Picture099.jpg
[http://i12.photobucket.com/albums/a221/Camacho111/Picture100.jpg
My S-10 is not setup for comps!
It would also help to know whether your metering was legal (sealed up) or outlaw (if a door or window is open).
On mine, I gain 3.9 dB by opening it up...I go from 143.6 on the dash to 147.5 on the dash. THERE IS A HUGE DIFFERENCE SO PLEASE TELL
Eric
Eric
Don't consider it "legal" or "outlaw" In MECA, the LEGAL way of measuring is in the kick with a door or window open if you want. I build accordingly. Saying "outlaw" makes it seem as though that our scores don't mean anything if they aren't "legal"
So i'd say just tell us where the mic is at, and if you have a door/window open.
durty jerz pwns you!!
143.3 db on the termlab
1 12" jl audio w7 in a 2.5 cu ft box tuned to 40 hz with 1 jl audio 1000/1.
kenwood ex. kvt 915 h/u with 160 amp alt and yellow top battery.
DEF NOT SET UP FOR SPL lol
Give me 3 yrs...
vehicle - 97 s10 reg cab
setup - 2 auduobahn alum12Q's 12"
box - 2 seperate sealed box (mdf) with the amp rack in the middle
hit about 117 db with the meter on the passenger side dash both windows down
FI Car Audio FTW!!!
Amp: Hifonix BX1500D
Sub: RE HC 15
Box: 4 cubes tuned to 30
MECA style in kick with driver's door and window open at 30hz: 142.9 (sumtin like that)
Reality - mic at headrest with passenger window down at 30hz: 144.0 :D
Dash: Aweful score... sumtin like 136.5 or sumtin at around 44hz
***UPDATE***
Vehicle:1990 s-10 regular cab
Sub: ONE 10" ALPINE TYPE-R!!! (unless otherwise noted)
Box: MDF (that's all the details I'm willing to give out right now )
Meter: Termlab
Scores
Termlab:
Kick: 148.9 and getting louder
Headrest: 145.8 (with the seXXX)
Driveby: 123.4 (meter is placed 6 feet away from the passenger door, 4.5 feet off the ground, only allowed to play music)
1 - 20 of 63 Posts
