1 - 17 of 17 Posts
G
Does anyone have a posi rearend on thier 2.2 and if so where can i get one, did you notice any difference??:stickpoke :far: :far:
I have an Eaton Posi Performance Differential in my 98 2.2 and it made one hell of a difference I bought mine from Summit Racing 1-800-230-3030 or www.SummitRacing.com for around $500.
G
i went to the website and it list 5 different ones, i gues it would help if i actually knew what kind of rearend i have on my trcuk now. what other changes did you make to your rearend
GM 10 bolt, 7 5/8 (7.625), 28 spline. 7 5/8 (7.625) is compatable with 7 1/2 (7.5).
The SLP zexel torsion unit is only $99 but there may be a difference between the two that im not aware of...
Project ZO6 S-10
Grounded do you have the 4.10 rear end STOCK, would that make a difference.
What I am trying to say is I have the 4.10 rear end, what one would I need. THANX
Project ZO6 S-10
Is it something I could Install myself (Basic hand tools)
No, I had 3.73s and I switched them out for the 4.10s. You would need a dial indactor to see how much play you have in your rearend. The Zexel unit probably will be fine for you, the reason I chose the Eaton posi carrier was when we went to do the gear swap we found that the spyder gears were pretty messed up, so instead of buying new spyder gears I just went with the new carrier.
G
Discussion Starter · #9 ·
grounded, so what is your top speed with the gear changes, and since mine is still all stock what do you suggest??
The gears through my speedo off by 10 mph. so my truck shuts off at 84 mph.
D'mon, The Eaton posi differential should work with the stock gears.
Phat 96, the venom 400 PCM helped out quite a bunch but I do not know the horsepower gains.
HEY GROUNDED I HAVE 3.73s GEARS WHERE DID U GET UR 4.10s AND HOW MUCH DID EVERY TING COST (GEARS POSI AND 10 BOLT)
I bought all of these items from Summit 1-800-230-3030 or www.summitracing.com. I paid $193.95 for the Richmond 4.10 gears (part number RMG-4900091), I paid $95.95 for the Richmond Gear installation kit (part number RMG-8310441), I paid $439.95 for the Eaton Posi Performance Differential (part number ETN-19599-010). The S-10 rearend is a GM 10 bolt, 7 5/8 (7.625) ring gear, 28 spline. With the ring gear on the GM 10 bolt 7 5/8 (7.625) and 7 1/2 (7.5) are interchangable. Also for the installation you will need a bottle of GM Limited Slip Additive, and several bottles of non-synthetic gear oil.
1 - 17 of 17 Posts
