1 - 20 of 21 Posts
I picked up a 87 Blazer 2wd has 350/700r4 308 gears. I would like to out a posi traction unit in it but don't want to spend a lot because down the road I will probably but a better housing in the truck.
I'm told it should have a 7.5 rear end in it. What options is there ?
I came across a used unit out of a newer 90's Camaro with very low use are these the same ?
If it has the 87 rear it is a 7.5" 26 spline. The easiest and cheapest thing is to find a later 7.6 with factory gov-lock or keep looking until you find an 8.5". Don't waste money on the 7.5" 26 spline.
Any 2wd pickup or blazer, 28 spline was 89 up though there will be varying gear ratios. The code should be in the glove box G80 is the gov-lock. I think we have a sticky with gear ratio codes. Get the whole rear end, I believe 98 up are disc.
Actually, I wasn't aware the pickups didn't get them, I've only had first gens until I bought a 2003 crew cab. No problem though the 2wd blazer rear end will bolt in, got one in my first gen.
Administrator
It should have a tag on the rear with all of the pertinent info. If not...count the teeth and do the math.
Doesn't ford put the number of teeth on the ring gear like most vehicles? Like 41-11 for 3.73?
I suspect the 41? in the pic is part of that. Ford didn't offer a 41-10 (4.10 ratio).
Discussion Starter #18
Well I heard that they did I read that it was the two numbers after the letters and the next two letters. Which would be the 41.
1 - 20 of 21 Posts
About this Discussion
6 Participants
jayyk31
S-10 Forum
Full Forum Listing
