RUSTHOLYUM
I just finnished up on the link intall...
I noticed the rubber polyurithane ends grind and squeak
Do I........loosen it up a turn or 2 till its gone?
DO I........lube that thing?
:bag: :whip:
who needs a sway bar? if you have side to side that is.. just pull the end links back off and apply some grease to it, then reassemble.
don't use any thing that is aggressive to the poly bushings, like Pb blaster, use wheel bearing grease or Vaseline
I was thinking sway bar end links, but it really doesnt matter, the four link end links will be the same thing.
I have jasons link bars on my truck, and during assembly I smeard vaseline over all the poly joints, no squeaks at all!
not real sure, my has been there for a few months now, and no squeaks yet. If you want you could just use the grease. vaselne is similiar to grease, so it should last a good while.
