1 - 18 of 18 Posts
I have a Civic now
Who has done this and what do i need, i wanna do this hardcore too, also wanted to know about my rear wheel size? i took my 17's off yesterday and didnt realize how wide my rear tires were, im runnin 235/40 in the front and 255/40 in the rear, can that be put on an 8 in wide rim, or is it a 9.5in wide rim??
Nathan:idea:
hmm
if you have access to a high speed buffer(not a waxer), you can use a wool pad(likethey use to buff paint with), and a mild compound(I like 3m perfect it 3). This stuff is actually used to buff paint, but Ivefound billet has a lot of the same qualities as paint, being that it is soft and what-not. I finish them by hand with eagle one, or mothers aluminum and mag polish. I have also used meguiars no. 7 handglazeto finish them.
I bought a custum polishing bit from a hot rod swapmeet for $3.
This thing WORKS! I used it with Meguiers polish and it gave my Centerlines a chrome-like finish, better than new.
The bit is dirty, it should be white. It turns black after polishing.
I have a Civic now
Polishing bit
So thats pretty much the same thing as like a 5inch buffing wheel you can hook up to your cordless drill right? That what I had planned to use, and also ARCdidit, is this 3M stuff called "Perfect It 3" ?? Will this get rid of the brake dust pitting on the inside edges of the front wheels?? I'm using a Dremel tool for that?? Thanks for all the info everyone, and SSNOS i will get those measurements in a bit, called in sick to work today, lol.
Nathan:drinkhaha
yeah
its a compound, so it will get rid of a lot of imperfections. Clean them real good first though. I like to use that meguirs"hot rims" cleaner-thats the best stuff I have found yet. If you have a scratch, you can sand it out, with nothing rouger than 600 grit wet or dry(used wet). Those wheels you put on makitas work well, however they don't turn fast enough to take out big scratches. These are a set of colorado customs I had(not the set I sold), and they were absolutely trashed!!! The guy drove them through the winter(MI!!), and they had salt marksandeveryting else on them. Using the technique I described, I gotthem all really nice-actually as shiny as new. I wis the pic turned out better, but it's too damn cold to take pics outside!!!!
I have a Civic now
Hello Ladies!!!!!!!!!
Nice pic, didnt you post some on here with some nekkid chick on your truck?? Anyway, clean them real good and what about the brake dust pitting that i have on the inside edges, sand that out too?? Thanks again for the info!
Nathan:thumbup:
I have a Civic now
Discussion Starter · #11 ·
One last thing
Hey ARCdidit, i checked on that 3M Perfect It III, they have a rubbing compund, quick cut rubbing compound, and a machine glaze or machine finish, cant remember the last one, do i want to just get the rubbing compound?? And a quart will be enough right?
Nathan:idea:
1 - 18 of 18 Posts
