i want to get one for mine but how do i go about filling it with fluid again. i know theres a tube i replaced it with a breather on mine....also. any one got part number for one of these for summit or jegs. :afro: also can i get liek some matching bolts to put it back on with. mso tof my shit has like a layer of rust and flaking metal and i need to clean it all up some.
LEAD FOOT LARRY
On the drivers side of the housing, just behind the yoke you will see a square hole.
Look closely and you will see it is a PLUG.
A 6 inch long 3/8 inch extension fits it perfectly.
Remove it and after you have your new cover installed, put your fresh 75W-90 gear lube in thru the hole. You will need about 1-3/4 quarts.
