1 - 2 of 2 Posts
Hi Everyone,
I'm actually over from a full size chevy forum (own a '88 F/S chevy) but my father has a '99 GMC S15 and his power window quit today. I removed the motor from the truck today and it was a NIGHTMARE!!! The regulator and the motor are riveted in, and it appears, unless I shave the heads off some bolts and weld them to the regulator (due to clearance from the geared swinging arm so close to the rivet heads) I won't be able to get the new motor back in!
Someone who has replaced a motor please tell me - am I making too much of this? Are you supposed to replace the entire regulator assembly when the motor quits? It almost seems that way from the way the assembly's made. I use rivets quite a bit, but these mothers are BIG! Much bigger than the 3/16th my gun uses.
ANYONE who has changed their own window motor PLEASE give me some insight!!
Thank you,
Brian
1 - 2 of 2 Posts
