so im 100% ready to lower my dime, but im still spooked on the pinion angle shims from JTR im going 4/4.5 with zq8 leafs and blocks so like what should i do? what have people done
Administrator
3" 3* blocks from member hi_im_sean...Can be had with setback also.
http://www.s10forum.com/forum/f12/3-3-blocks-716866/
Be aware...you may have to shorten your driveshaft also. Sometimes the setback will give you enough room. I went with a shortened driveshaft since it came with new joints anyways. Pull the driveshaft when you drop it, then reinstall. If it isn't go back in, then you have to make a choice. If you leave it in and it's too long, you will destroy your tranny.
