joe said:
no won't work the b&m shifter is all 1 pc. the shift handle doesn't screw on to the base like the stock one does.
It wont be one piece if I cut it to the same length as the stock one.
What I need to know is if its hollow, and if its roughly the same size in diameter as the stock shifters male threaded end.
Ive got die's to run over the short throw stick to make threads so that it will go inside the stock shifter handle... But I dont want to get it, and it be hollow or way too small to even work with.
:welder: I guess the worst thing that could happen is welding a bolt on the end of the shaft, once its cut, then use that to thread the stock shifter handle on to the short throw's stick. I'm sure the boot would hide every thing.
