1 - 20 of 37 Posts
Registered Pwnz0r
I'm still new and I did a quick search for it on here and didn't see anything, but I need to know how to take the door panels off of a 96. I found the thread on how to take the 98+ doorpanels off, but its different for 94-97. When I tried to do it, I could get it loose but something around the armrest was holding it on, and I'd rather not break anything. Any help is greatly appreciated.
It's a Blue thing...
There is a plastic strip you take out of the arm rest and underneath are 2 bolts that must be removed before it will come off.
Registered Pwnz0r
No, I've got those out, theres something holding it on more towards the rear of the armrest.
VILLE
just pull real hard or get a sawzall
Registered Pwnz0r
If I can avoid it, I'd really like to not **** anything up
Registered Pwnz0r
Discussion Starter · #10 ·
JMew03 said:
did u take the window thing off
No, I didn't even think that far, because theres still something holding it on the end of the arm rest. But even if I did figure out the armrest problem, do the handles just unscrew?
bodydropped on 22s!
yeah use some needles noes plies to get the clip off.. its a pain with out the right tool. good luck!
Registered Pwnz0r
Discussion Starter · #13 ·
I just went outside and looked at it really fast and loosened those two screws. I don't know, maybe the window handle is the only thing keeping it from coming off. I don't really have time to work on it today, but hopefully thats the only thing. Thanks guys.
Registered Pwnz0r
Discussion Starter · #17 ·
JMew03 said:
u can kind of see it in this picture
Yeah theres that screw and then the two in the arm rest.
Registered Pwnz0r
Discussion Starter · #18 ·
Now that I think of it, I may have trouble getting around the door handle too, because its shaped differently.
bodydropped on 22s!
well if all those are off and the window crank is off just start pulling.
they are hard to get off for a reason. dont be scared
Registered Pwnz0r
Discussion Starter · #20 ·
I think once I get the crank off I should be able to get it off.
1 - 20 of 37 Posts
