Ok now here it is guys. I have a 976 sdime single cab. I have done a cut threw to the bed for a costom box for two solo 12 L7s. Now you know in a sdime you have the plastic under the rear window and the carpet under it. So now I have my plastic with somewhat part of the hole that leads to the costom box and then no carpet just the uglyass metal and my big hole! So here is where I need your brains and help!
I was thinking of fiberglassing the back in. have all the goodies and fiberglass mat but don't know what I really need to do? do I a were the carpet use d to be use a small wook sheet like cork bord for the foundation and lay the glass on it or use sheets to cover it with the wood under it and then lay out the resin and then when that drys pull it out and start laying the glass onit? ANY HELP WILL BE GREAT!!! :guitar:
