Is there a way to disable passlock for good. I know about the bypass module when using a remote starter, but I need to disable it. I put a 2000 engine (2.2) in a 1995 truck and the only thing holding me back is passlock. The truck starts up then dies after 2 seconds. If I disconnect the comp harnesses turn the key to run then connect the harnesses, turn the key the truck starts up and runs fine, till you turn it off then passlock acts up again. It might get alittle old doing this every time I turn the truck off. Thanks in advance, Sgt Sparks
