Has anyone else had this problem, the back window on the passenger side always rattles, shakes, and makes noises... When I push on the black thing to put the window out, it will stop... But any little vibrations or bumps will make the thing rattle like a b!tch.... Annoying as all He!!... Does anyone know how to fix this problem??? PLMK
Thanks,
Striker
turn down the system:p
Early Member
The plastic trim,that surrounds the window and jump seat, may be what is actually rattling. Pull the panel off and check the insulation.
i ahve the same problem. but mine did not start until after i got my system put in. hmm i think i see a connection here. loud stereo + ext cab windows = loud rattle. some times it is the little things that make you smile and piss you off at the same time. is there anyway to tighten the window or trim?
