1 - 20 of 20 Posts
Not that my truck and I will be on the show, but let's see who can guess the closest!
I will be running at Mission Raceway B.C., about 32' above see level. Temp will be likely be in the 70º range.
My truck is a 2dr. AWD Jimmy automatic. 153,000 miles
3.73 gears
245/45/15 tires.
The only power mods are a 3" cat back exhaust with a Magnaflow.
The truck and transmission run with no issues.
I will be running this coming Friday May 3rd. I will likely get 3 runs and will post the quickest time slip.
Not my first time, I've run my '89 Jimmy and '95 Jimmy. I will not give you hints or clues as to how the other trucks ran.
So let's see your guesses. If you guess more than once your last guess will be the one used.
16.3
Discussion Starter #16
Final run was a 16.653 @ 79.63 MPH.
I think I discovered the best 1/4 mile performance upgrade, remove the speed governor. Stock governed speed is 100 MPH. With my lower than stock gears and short tires I coasted the last 100' through the lights. My top speed is 79 MPH.
Discussion Starter #18
This was my 3rd race.
`````````Me````````````````Him
60'`````2.267``````````````2.498
330'````6.785``````````````7.064
1/8````10.586`````````````10.543
e/t`````16.748````````````15.958
I saw the car with the hood up, he had NOS on it, don't think he used it.
1 - 20 of 20 Posts
