For a while now I've had a parasitic draw of 4-8A (varies whenever I measure it) on my 1992 S10 with the 4.3 TBI and 5 speed. This would discharge the battery overnight to the point where it wouldn't start, right now am just disconnecting the negative whenever I park it.
To troubleshoot I first tried pulling all the fuses and shunts in the cab fusebox one by one, but the draw didn't measurably decrease with any of them. Next tried removing the alternator and starter motor from the circuit by placing the meter between the battery positive and ring terminal (to fusible links) removed from alternator, see below photo, did not see any decrease. Note that the battery positive is also removed from the alternator so shouldn't be any path to what I believe is the 2-pin connector to the instrument cluster on the side of the alternator.
From there I saw there is an unfused connection between the battery and starter solenoid via ignition switch, so tried pulling the steering column connectors, still no change in the draw. Pulled the headlight switch connectors as well and no luck, as well as the ECM connectors although I am fairly sure those are fused so would have seen a drop when checking the fusebox. At this point I'm scratching my head what is left to check, evidently there is still something drawing current. Would appreciate if anyone has thoughts what it could be or has run into a similar problem.
I've attached a couple wiring diagrams from my Chiltons manual below, with the spots highlighted where I have pulled a connector or ring terminal to interrupt the circuit if that is helpful. Note that while the fusebox is not circled I have tried pulling all the fuses and shunts in there.
A friend of mine has an Astro van with the 4.3 Vortec which also has a big draw somewhere other than the fused circuits, so I'm wondering if this is a common GM issue but didn't see anything similar that's been resolved when I searched.
