im looking for some pics of a parallel 4 link setup installed on an s10. i've seen them installed on a ranger but i want to see it on an s10. anybody have any? i know larry probably does. thanks.
Brian
Brian
Doesn't seem like there is enough room under there though. Unless u built a new back half to accomidate to bars on each side other than that it seems like it wouldn't lay out cause it would layout on the hangers that the bars are attached too.SlammedDime said:Its easy to fit one on a dime, as long as you relocate the gas tank.
Sorry, I don't have any. I prefer using triangulated four links. A parallel is easy to install, if you get a good one. The brackets are pre-spaced, and go right on, real easy.RedSpeck_09 said:i know larry probably does. thanks.
Brian
It sounds like the gas tank is an issue to me since you are MOVING it to the rear!RedSpeck_09 said:you can email me at [email protected]. the fuel tank isn't an issue. im installing a fuel cell in the rear right now. i'll have some pics up later.
