Every time i think i fixed it, it comes back. Here’s a list (from memory) of all the parts Ive replaced in the 20k miles that Ive owned this 2003 blazer.
-spark plugs, wires, distributor assembly
-coil pack, ignition control module
(Essentially replaced the entire ignition system)
-crank position sensor
-maf sensor
-spider injectors
-intake manifold gaskets
-rear main seal
-radiator
And more Im sure. The engine light comes and goes. It makes a rattling noise under acceleration only in the 1200-2500 rpm range. bit of rough idle. Slight hesitation. Im tired of throwing parts at it.
i was wondering if an exhaust leak at the y-pipe after the manifolds can cause a misfire? I had to remove the exhaust when I pulled the transmission and one of the studs on each side got stripped so two nuts, one on each flange, are not seated. Could this cause an exhaust leak significant enough to throw of o2 sensor readings and mess up the A/F ratio?
Im beginning to think it may be a mechanical issue, either timing chain or valves. Ive done a compression test but the engine was cold and it got up to about 150 psi but quickly leaked down. Is that normal?
sorry for the disorganized flurry of information, just getting fed up with this machine. Any help is appreciated. Maybe its time to let the pros fix it.
-maf sensor
-spider injectors
-rear main seal
-radiator
