1 - 13 of 13 Posts
It's a 4. something
Re: P200 engine code - injector control
if you're referring to the code then he is missing the prefix 0 so it would be p0200
sorry OP, no clue what would cause it
What ecm is it? I have heard some of the early one's throw those codes. Only way to fix it, is to get a new ECM. I believe I heard that from PoconoJoe, not sure.
Injector might be going out or stuck open..you might not tell any difference in the way it runs, but there is a malfunction in one of the Injectors and/or the circuit.
From what I have heard, no. My understanding is that it is just a computer issue, but I don't have any first hand experience with it. Drive it at your own risk, but if it were mine, and I knew I had all 8 injectors working, and my a/f ratio was cool, i'd be toolin down the road.
Bad wire. connector or PCM issue
DTC P0200 Injector Control Circuit
Refer to Engine Controls Schematics, Fuel Injectors for complete circuit details.
Circuit Description
The PCM enables an injector on the intake stroke of each cylinder. Individual cylinder fuel control is referred to as Sequential Multi-port Fuel Injection (SFI).
Ignition voltage is supplied directly to the fuel injectors. The PCM controls each injector by grounding the control circuit via an internal switch called a driver. The primary function of the driver is to supply the ground for the component being controlled. Each driver or control circuit is equipped with a fault line which is monitored by the PCM. When the PCM is commanding an injector ON, the voltage of the control circuit should be low. When the PCM is commanding the injector OFF, the voltage potential of the control circuit should be high. If the PCM detects the injector control circuit voltage other than what is expected, the PCM sets a DTC.
Conditions for Running the DTC
The engine speed is more than 400 RPM.
The ignition voltage is more than 6.0 volts but less than 18.0 volts.
Conditions for Setting the DTC
The PCM detects the wrong voltage potential on any injector driver circuit for 5 seconds.
Action Taken When the DTC Sets
The PCM illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Use a scan tool in order to clear the MIL and the DTC.
Diagnostic Aids
Important
Remove any debris from the PCM connector surfaces before servicing the PCM. Inspect the PCM connector gaskets when diagnosing/replacing the PCM. Ensure that the gaskets are installed correctly. The gaskets prevent contaminant intrusion into the PCM.
For any test that requires probing the PCM or component harness connectors, use the J 35616-A connector test adapter kit. Using this kit prevents any damage to the harness connector terminals. Refer to Using Connector Test Adapters in Wiring Systems.
A misfire may not be apparent at idle. The misfire may only occur above idle under a load. Road test the vehicle and monitor the misfire current counters.
Observe, if more than one cylinder is mis-firing, the scan tool may only display one cylinder mis-firing. This will not be apparent until the repair is completed. Also, if an injector fuse is open for one side of the engine, the scan tool may only display 2 or 3 cylinders mis-firing.
When the injector driver is disabled, an engine misfire will be apparent and a misfire DTC sets.
For an intermittent condition, refer to Symptoms .
Test Description
The numbers below refer to step numbers on the diagnostic table.
This step determines if a malfunction is present.
The Misfire Current Counters will not increment if certain DTCs set at the same time or after DTC P0300 sets. Refer to conditions for running DTC P0300 for applicable DTC list.
If more than one cylinder is misfiring, the Misfire Current Counters may increment for only one cylinder. Example: Cylinders 1 and 8 are both misfiring, yet only cylinder 8 increments on the Misfire Current Counter.
If one injector fuse open, only two or three Misfire current counters may increment for the corresponding side of the engine.
There are two ways to isolate a malfunctioning injector circuit:
DTC P0300 indicates a misfire is present. So use the Misfire Current Counters to locate the cylinder that is misfiring.
If no misfire DTC is present, Start and idle the engine while monitoring Misfire Current Counters. If a misfire is present, the Misfire Current Counters will increase for a cylinder that has a misfire.
The injector fuses also feed the ignition coil/modules. Thoroughly inspect the circuits going to the ignition coil/modules for a short to ground. A shorted ignition coil/module may also cause a fuse to open.
Inspect the injector connections before replacing the injector. A faulty connection causes an inoperative injector.
Disconnecting the PCM allows testing the continuity of the circuits with the DMM. This aids in locating an open or shorted circuit. Tests for an ignition feed circuit that is shorted to ground.
Fuel Injector Circuit Check Step
Action
Value(s)
Yes
No
1
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
Install the scan tool.
Start the engine.
Monitor all the Misfire Current Counters on the Misfire Data List (There are a total of 8 counters. One counter per cylinder) with a scan tool.
Are any of the Misfire Current Counters incrementing?
Go to Step 4
Go to Step 3
3
Monitor the Misfire History Counters on the Misfire Data List (There are a total of 8 counters. One counter per cylinder) with a scan tool.
Do any of the Misfire History Counters indicate a number other than 0.0 counts?
Go to Step 18
Go to Diagnostic Aids
4
Are the injector fuses OK?
Go to Step 5
Go to Step 8
5
Turn OFF the ignition.
Disconnect the injector(s) harness that the Misfire Current Counter is incrementing for.
Turn ON the ignition, with the engine OFF.
Probe the injector harness ignition feed circuit with the test lamp J 34142-B connected to ground. Refer to Probing Electrical Connectors in Wiring Systems.
Does the test lamp illuminate?
Go to Step 6
Go to Step 10
6
Connect the injector test lamp J 34730-2C to the isolated injector harness.
Start and idle the engine.
Does the injector test lamp blink?
Go to Step 7
Go to Step 11
7
Inspect the injector harness terminals for poor connections. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
If you find a poor connection, repair the condition as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
Did you find and correct the condition?
Go to Step 19
Go to Step 9
8
Disconnect the four injector harness connectors related to the fuse that was open.
Probe the injector ignition feed circuits of one of the injector harnesses that are disconnected with the test lamp J 34142-B connected to B+. Refer to Probing Electrical Connectors in Wiring Systems.
Go to Step 13
Go to Step 9
9
Important
Return to this Diagnostic after performing the Fuel Injector Coil Test.
Perform the Fuel Injector Coil Test. Refer to Fuel Injector Coil Test - Engine Coolant Temperature (ECT) Between 10-35 Degrees C (50-95 Degrees F) .
Did the Fuel Injector Coil Test isolate an injector condition?
Go to Step 15
Go to Step 14
10
Repair the injector ignition feed circuit to the isolated injector. Refer to Wiring Repairs in Wiring Systems.
Is the action complete?
Go to Step 19
11
Important
Disconnecting the PCM may eliminate the short to ground, or short to voltage if the injector circuit is shorted to another PCM circuit.
Disconnect the PCM connector C1 located on the same side as the manufacturer's logo. Refer to PCM Replacement/Programming .
Test the injector control circuit for an open, short to ground or a short to voltage. Refer to Circuit Testing in Wiring Systems.
Is the injector control circuit open or shorted?
Go to Step 12
Go to Step 16
12
Repair the injector control circuit for an open, short to ground, or a short to voltage. Refer to Wiring Repairs in Wiring Systems.
Go to Step 19
13
Repair the grounded ignition feed circuit to the injectors. Refer to Wiring Repairs in Wiring Systems.
Replace the open fuse.
Go to Step 19
14
Repair the intermittent short to ground in the injector ignition feed circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 19
15
Replace the faulty injector(s) that was isolated. Refer to Fuel Injector Replacement .
Go to Step 19
16
Inspect for poor connections at the PCM. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
Go to Step 19
Go to Step 17
17
Important:
Program the replacement PCM. Refer to PCM Replacement/Programming .
Replace the PCM.
Go to Step 19
18
Inspect the appropriate injector circuit for the following:
Poor connections at the injector and the PCM terminal.
Intermittent shorts to ground.
Intermittent opens. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
If a condition is found, repair as necessary. Refer to Wiring Repairs in Wiring Systems.
Go to Step 19
Go to Symptoms
19
Select the Diagnostic Trouble Code (DTC) option and the Clear DTC Information option with the scan tool.
Idle the engine at the normal operating temperature.
Select the Diagnostic Trouble Code (DTC) option and the Specific DTC option, then enter the DTC number with the scan tool.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this test ran and passed?
Go to Step 20
Go to Step 2
20
Select the Capture Info option and the Review Info option with the scan tool.
Does the scan tool display any DTCs that you have not diagnosed?
Go to the applicable DTC table
System OK
1 - 13 of 13 Posts
