Hi, I have a 2002 Sonoma 4.3 Vortec & Ext. cab.
I keep getting a p0174 and p0171 codes. Cleared the codes but I saved the freeze frame data. I was trying to find if i had a vacuum leak and the only vacuum hose I could find was the one that connects to the front left fender (in the right of the engine bay) I've been dealing with this for a while now.
Here are some of my symptoms :
-When truck reaches ~150-210, after I turn it off and let it sit for about 5 minutes it won't crank, unless I let it sit for about an hour or I shoot starter fluid down the throttle body, even then it barely wants to crank.
-Earlier today I was on the interstate and it seemed like my transmission or engine was bucking at around ~55mph and every so often between 70-80mph ( although this might be unrelated)
-Low idle speed (500-600RPM) usually idles at about 750-800
-Once every blue moon I might get a misfire (although that might be the plugs)
I recently replaced the fuel filter, plugs & wires (1-2k miles earlier), distributor cap, air filter, and fuel cap.
I know it may be the fuel pump it's just I'm trying to exhaust all my options before I have to do that.
What are some things I should check? and is there a vacuum line diagram or picture i could use to find all of the lines?
ALSO, I do have a scanner with access to live data. What are some points I should look for that could help diagnose this?
On the freeze frame data;
Long term fuel trim B1 ; 25%
Short term fuel trim B1 ; 1%
Long term fuel trim B2 ; 25%
Short term fuel trim B2 ; 1%
I'm not a mechanic by any means so ANY info would be appreciated
