Listen to this one fellas..... I was in the process of putting Sea Foam through my system by way of the brake booster vacuume line. Anyways, I was spraying it with the straw attached mind you. Then before I knew it the straw was sucked into the line. I thought it just fell off, but I searched around and found nothing. So guys what do you think I should do? I looked down the throttle body...nothing. I thought hmmm maybe it is stuck in the line and more than likely at the 90 deg fitting on the manifold...nothing. So it was sucked all the way in.
Any suggestions???
