I lost the thread telling how to caculate a tire size...So a little help would be great. If i wanted to put tires on a 18X8 have some meat on the tires but not a whole lot what would the BEST tire size to go with...Or at least give me the dimension I need for the 8" wide tire...thanks alot for your help. Mike
Gaaoooooo
I'd run atleast a 245/40 on 18's, my style would be to go as big as possible in the rear but you may just want to run 245's all around.
Registered Loser
Yeah i tried that...Im getting upset at both places i cant get the image of my rims that i want loaded up so ill throw you all the link and you can tell me what you think. Im going for the mondellos or the Nogaros. Tell me what you think. If anyone has any idea on what I should get for the 18X8s really the only size im looking for is the 8s let me know. Mike
Heh nevermind im a huge retard...Im looking at going 215/45/18 or 225/45/18 I have not decided...Its going to be a hard decision...LOL...what do you all think.
Calculating tire size is cake. We will use my tires for an example.
I run 235/55/18s all the way around.
235=WIDTH(in MM)
55=SIDEWALL HEIGHT in PERCENTAGE OF WIDTH
18=RIM SIZE
To convert MM to IN multiply by .03937 OR divide by 25.4. Those are both standard ways to convert MM to IN.
235MM x .03937=9.25"
9.25" x .55(which is 55 percent) = 5.09"
BUT REMEMBER...There are two sidewalls on either side of your wheel. So you double that number.
5.09" x 2 = 10.18
Add the diameter of your wheel to that number and you got your final tire size!
10.18" + 18 = 28.18"
