1 - 16 of 16 Posts
I have a 2003 Chevy s10 4.3 with 179000 on it and the thing runs amazingly and I love the truck but the oil pressure worry’s me on start up I have 45 psi of pressure at idle and upon warning up it stays steady at 15 to 20 psi I’ve changed the oil recently as well are the sensors in the trucks common to fail? Also when I cut the truck off the pressure stays at 15 till I cut the truck back on so maybe the gauge is messed with as well idk id like some options thank you
· B4U Task Force
If you're using text to talk, it's not working. You need to edit this post and use punctuation. Posts need to be legible or they will be deleted. The three vertical dots in the right hand corner will bring up the edit button.
No offense but I’d greatly appreciate it if you’d just stay off my post if you don’t have anything helpful regarding the post I need help with a issue regarding a truck I didn’t ask for help with punctuation thank you and god bless
· B4U Task Force
I'd greatly appreciate it if you'd read the forum rules...
12. If a message is unreadable due to spelling and / or grammar, it may be removed. We don't ask you to be a 'Spelling Bee' champion, or an English Major, only that you post messages that are legible and make sense.
Vertebrate Nature Carnivore Organism Mammal
😂😂 you realize you could have just passed this by but instead you took time out of ya day to post a rude comment on someone genuinely asking a question he needs answered I pitty the life you live to feel the need to comment something like this
· B4U Task Force
You could have avoided this by using 5th grade English skills. Take a week off, stand in the corner with Willie Oleson, and practice.
Oh...BTW...your pressure is fine. These gauges are not the most accurate. Put a mechanical gauge on it to confirm pressure.
· Premium Member
Currently: 96 4wd XCab, 85 2wd S15 XCab, 82 2wd lwb Sport, 95 2wd Jimmy w/95 LT1
Just exercising my right to vote here - I'm with Rhotpursuit, garbled or careless messages are not as likely to be understood, take more exchanges unnecessarily, and add a step for me, and maybe others, of deciding whether to finish reading them.
Highly second mech oil gage. Being old skool I use SW oil and temp gages on all my stuff. They tell the truth.
· Premium Member
Yep - what he said.
94 2 door Blazer 305 V8 700R4 3:42 rear PS PB A/C PW PM Bluetooth
I have a question, that relates to this thread.
My oil pressure reads low as well on my 94S-10 Blazer. The oil pressure switch is a 3 wire of which if I'm not mistaken, one wire goes to the fuel pump and if the oil pressure gets too low, the sending unit will cut the fuel pump to save the engine.
How would one go about installing a mechanical gauge and deal with the wiring to the fuel pump??
I agree it's the OEM gauges in the cluster that are of questionable reads.....
1 - 16 of 16 Posts
