Finally got my 97 back running after the fuel pump issue that I had, When I am taking off the gauge goes towards 0 if the clutch but when the clutch is pressed the goes up like normal anybody have any ideas as to what is causing it?
i saw what you did there!
probably ground wire issue
or loose wire somewhere under dash
sounds like another gauge is grounding through ur oil sending unit gauge..i would remove the cluster make sure all plugs are plugged in nice and tight....it could be your oil sending unit too ive had a few that shitted out like that they would just go crazy
Thanks for the replies I figured it was a ground or something simple, its been working fine and just out of the blue started working backwards :rotf: just have to get the time to tear it apart and figure it out :cool:
